1 - 3 of 3 Posts
Hello to all! Gentlemen, I'll intro later. 20 year H-D mechanic here doing a favor for a friend. I'm replacing the rear rotor and need to remove the rear axle to access the rotor bolts and to replace a "drive pin". Question - The 46mm nut capturing the left side of the "splindle" , left hand thread or standard? and do you/should you replace the "special" nut? lastly, I'm big into torque values so whats the spec? THANK YOU! Respectfully, TK.
Right hand thread, and 107 ft lbs. No need to replace the nut. A good way to loosen it is to stand on the rear brake pedal and use a breaker bar.
1 - 3 of 3 Posts
