Hi all,
I've got this odd problem on my 2005 1050. When I push the starter button there is a short (half second) delay before it will crank the motor. Is this normal?
Just last night it didn't turn the motor over at all, so I turned it on and off again, flicked the stand up and down and after a few tries it did turn over but after a delay.
I'm not sure whether they all have a delay or not, and if they don't what to look for. When it turns over, it fires up right away. The bike's got a new stator, RR, and battery. It's charging well, and apart from this strange starting delay is running well.
Thanks for any replies
GC
I'd try taking the starter button apart (carefully, tiny parts inside) and cleaning first. In my 2005 this issue has popped up a coupla times over the years. Between the clutch switch, starter button, ECU relay, sidestand switch and block ground - an hour or so with hand tools, emery cloth and contact cleaner takes care of if.
Ah, cool, thanks for the reply. -It's kinda helpful knowing that it's a thing. Weird.
Did you manage to take the clutch and side-stand switch apart then?
Also, where's the ECU relay and the block ground? Thanks Surya :)
Been a while but ya the clutch switch does come apart, the sidestand switch I don't recall. The ECU relay is on the under seat fuse/relay board. The main ground wire mounts to the top of the block below the rear of the air filter box. More generally if you can get to these switch/lead contacts, squirt some cleaner in and exercise or scrape them you should see results. I'd coat in electrical grease after resolving to hold off corrosion.
