I've had a search on Triumphrat for issues for the Denali mini sound bomb but haven't seen anything other than install guides for the bigger versions which rely on relays and come with compressors which are being put onto the Bonnie's.
I've got a 2005' speed triple 1050 and recently bought this horn from a vendor as a plug & play quick mod without the hassle of installing a relay and to get a better low tone and to get away from the high pitched distressed sounding stock horn.
I've gone to install it today, visually plotted where it was going to sit, removed the old horn's bracket with the horn attached, carefully bent the connectors on the Denali to an upwards position and connected them to the stock connectors. I've then turned on the ignition and pressed the horn button to find the headlights dipping and the faintest sound of a click noise from the horn as if it was under powered - so I've started up the engine thinking this would resolve and unfortunately I was faced with the same issue.. so I packed anything up and put the horn back in the shed to investigate further.. the one thing I didn't do however was actually mount the horn and had it held in my hand and I'm wondering if that would of changed anything? Or if anybody knows the issue behind it?
