1 - 11 of 11 Posts
By any chance would a Daytona 600 gas tank fit on a Speed Four if the sub frames were swapped? Reason for asking is I like the D600 tail section but I don't want an edgy tail piece and a rounded everything else. Thanks in advance
yes, the tank will fit, but you will need more Daytona parts than you would think. You will need the following: tank, subframe, undertray, tail section, tail light and seats. You will also need a Daytona 600 battery which is different than the S4 and you may need to modify the wiring harness to fit (ask Chrisjames - he would know). it is a good amount of work, but worth it if you like the look and if you can find the parts at a good price.
jeff h
jeff h
Serious question:
How does/can the battery differ?
the battery on the S4/TT600 is a YTX12-BS while the Daytona 600/650 battery is a YTX9-BS. S4/TT600 sits upright while the Daytona 600/650 lays sideways.
from the Yuasa batteries site (http://www.yuasabatteries.com/vehicle_search.asp):
YTX12-BS Dimensions: 6" x 3.4375" x 5.125"
YTX9-BS Dimensions: 6" x 3.4375" x 4.1875"
If that's it, then I bet the S4/TT600 battery could be coerced into the undertray. The only electrical component that would be changed in the swap would be the tail light and the turn signals. I have an S4 and just took the plastics off the tail when they got battered. I bought a D600 tail light which is just screwed into the back. I don't know if changing the gas tank would change anything electrically, but just the tail and its plastics shouldn't require a change of wiring harness.
i was never trying to imply that the wiring harness needed to be changed. what i was attempting to say is that the leads to the battery may need to be lengthened, depending on how the battery is situated. i tell you this because i know that the TT600/S4 and the D600 wiring harnesses are completely different. it was challenging to say the least to fit the D650 harness onto my S4. i almost gave up and put the Daytona subframe and plastics on, but with some luck and help from a good friend/extraordinary mechanic the D650 harness was made to work.
The bikes look very similar, but the components were not designed to be interchangeable.
Jeff H.
we live in the same town, and I like being different so lets keep it that way. :D
he didn't.
both of you STFU!
there is only one FuryFour :D
1 - 11 of 11 Posts
