81 - 85 of 85 Posts
22Speed Triple RR, 08 Daytona, 05 Sprint St, 61 Honda Benley
i suppose the stock set up is +,- one degree, and chain stretch from exhaust cam to crank gear possibly retards both cams some, so testing it is a good idea on anything. I was hoping to be able to also compress the valves manually, while dial indicator is set up, so i can check valve clearance at various timing degrees. Not sure if there is enough room or if a special tool is needed.
When substituting cams, ie. exhaust for inlet or vice versa, the original sprocket for the cam being used is retained. However, timing is the issue here. The duration, lift, & overlap of the cam is machined into it already but, as you understand, the timing is what is sought to be controlled/changed. This is why adjustable sprockets are desired.
Before re-timing my cams, I checked the stock timing and was surprised it was not quite what the factory specified. Then, in attempting to re-time to my desired settings I find it very difficult to get it exactly where I wanted it and in the end I had to settle for "close enough is good enough".
At the time, aftermarket adjustable sprockets were not available so I decided my best option was to have the factory cam sprockets (both) slotted. This is hardened steel and easier said than done but I discovered "spark erosion" or EDM (electrical discharge machining) and managed to have them slotted using this process quite economically. I can dig up the drawing indicating the slot length & orientation if required.
Just a final note, this mod on a speed triple will make more power, especially in the mid-upper revs but the full potential will be stymied by the lower red-line of the 1050 motor.
Good luck.
Good luck.
So if using adjustable cam gears and an intake for an exhaust.... attach the adj sprocket to the cam pretending it's actually an exhaust cam... since that's where it's going....
Then actually measure where it ended up and adjust from there.
81 - 85 of 85 Posts
