1 - 2 of 2 Posts
My Dart Flyscreen is mounted to the headlight bolts. It this correct. I notice the headlight rises in speeds above 70.
That is correct.
The brackets for the Dart screen mount to the headlamp bolts.
They must tho be mounted at an angle where the tab-stops are in contact with the headlamp bracket.
This will stop the headlamp rotating upward as the screen leans back, under the pressure of the wind.
Unless you do some modifying, there is no adjustment of the angle at which the screen sits.
V.
1 - 2 of 2 Posts
