1 - 8 of 8 Posts
I assume my D1200 will be alright after what happened last night. I had a bit of trouble trying to start it but it started eventually. It was burning a bit of oil from the right exhaust can, not sure if I messed something up or if it's residual oil burning off, since that is the side it fell on. I had a pretty nasty backfire too while trying to start it so I hope it wasn't anything internal. I let it warm up and gently reved it, no problems.
Now back to my question. I had to take a sport bike specific course, similiar to an MSF course and during it I really pushed the Daytona to it's limits and I need to adjust my suspension really bad. I was wondering if anyone would be able to guide me on where to get started, I'm not too keen on suspensions. What I really need to do is get a Haynes manual for this bike. Anyway it's a stock suspension, I weigh about 210lbs, and I never ride two up. I'd like to get a nice stiff suspension too.
I did the MSRC a few weeks ago on the D12. I have Racetech front springs/oil with stock rear shock. I bought the RaceTech emulators or valves (can't remember which they are) but didn't install them as nothing matched in the supplied phots/instructions of the OEM cartrige bottom. Go for the uprated springs and you see the world o' difference.
Anyhow, it handled quite well for a 13+yo bike and easily kept the pace with the more modern bikes.
It might be a good idea to check the right side crankcase cover. There is a boss on the inside of the fairing that can hit the cover and crack or hole it, the leak won't be apparent until you get up to speed.
tritonwow,
Love the Daytona 1200. Did you have problems with cables/throttles etc? (Sorry - slightly off topic).
ffry, sorry 4 the threadjack. BEL I sent you a PM. Spondon makes me drool! I'd love to put a D12 engine in one of their frames!
ffry, I just reread your initial post and realized you most likely don't have a manual. I get into mine tomorrow and port the recommended setting for the stock suspension. Also, do a google search because I know I've seen some really good sites describing how to adjust properly from a stock setting.
Thanks, I am manualess. I do have a book though, "101 Sportbike Projects", which goes into great detail how to setup a suspension. Its just going to take some time to dial it in right but I know my current setup is horrible, waaaay to much sag. I just wanted to get a starting point if anyone had any sugestions.
Ok, I couldn't find it in the service manual but Haynes says:
Front fork
Preload Rebound Compression
solo - standard 5 6 6
- softer 6 9 8
- firmer 4 4 3
with pillion 4-5 4-6 3-6
w/ pillion and luggage 1-4 1-4 1-3
Preload - All the way out shows eight grooves; 1 (on top) through 8 (bottom one nearest the hexagon) The numbers above count down from the top.
Rebound (center of the preload adjuster) - has 12 positions; max setting is all the turned clockwise. numbers above are number of clicks turned counter-clockwise from max
Compression (bottom of each fork slider) - has 12 damping positions set the same way as Rebound
Rear shock (preload and damping; up to VIN 29155)
Preload Damping
solo - standard 2 or 3 2
- softer 2 1
- firmer 4 3
with pillion 3-4 2-3
w/ pillion and luggage 3-4 3-4
Rear shock (remote adjuster type)
Damping
solo - standard 6
- softer 8
- firmer 4
with pillion 4
w/ pillion and luggage 1-3
max is all the way clockwise; settings are the number of clicks turned counter-clockwise from max
Discussion Starter #8
Hey thanks a lot, that's exactly what I needed. I think I need to invest in the Haynes manual for the bike. I've seen online but keep putting it off fo some silly reason. Thanks again.
1 - 8 of 8 Posts
