1 - 11 of 11 Posts
Hello all - first time posting. Hope it works.
I can't claim credit for this, pinched it off another forum.
A caterpillar silicon O ring part no 8m4991, makes the perfect cruise control. Slide it over your bar end weight. When conditions allow - numbingly boring motorway stints, roll the O ring down towards the throttle. Just let it grip enough to maintain present speed. You can still, obviously, close or open the throttle but will feel the resistance of the O ring.
I ordered two from Finning Cat ( branches nationwide ). They cost me £11.50, posted for the pair. Apparently they are 2 dollars each from the states.
They work a treat.
I have been using that system for a while now, my mate has his own earthmoving company so "O" rings come very cheap for me. :D
Andy.
Holy cow! Send me £11.50 and I'll send you six of them! I'll pay the postage, too! I can get them at the corner hardware for less than $1.00 Shop around, Triumph stuff costs too much, you shouldn't get screwed for aftermarket stuff, too.
o ring
Hi all,
It appears that the caterpillar o ring that is mentioned above is the best due to the silicon construction. I ordered 3 (just to have spares!!) for my bike and they work great. I have read that the non caterpillar o rings do not work as well.
Just my 2 cents :D
Hi Atokadok,
thanks for posting the photo.
With regard to pricing it's all par for the course this side of the pond. I have the Land Rover and Triumph factories in a 30 mile radius and I bet we pay more for our spares than you do.
Two years ago I had to buy a dedicated ignition key for my Jeep - £135...
It's all part of what makes Britain " GREAT ".
Cheers John.
I have been using this for a while too although have to say it is a bit tricky to slide across and get it to stay there!!
Atokadok your handguards look great but do they make it even harder to move the 'crusie control' across?
I was given this ring by a fellow Tiger driver and it works well. Be careful when pushing it off the throttle so that it doesn't become roadside trash. I wonder where mine is now.
The handguards do not interfere with the cruise control. The cruise control (aka CAT o-ring) fits right in between the space where the end of the rubber hand grip ends and the bar end starts. The space is about 2 mm and in not visible in my pictures, but it is there. The handgrips have a slight left to right movement in them which creates the space.
It's pretty easy to "roll" the o-ring into that space but I find it a little trickier "rolling" it out of th space back to its resting spot on the bar end. (stock bar ends on my '06 have a slight depression in them where the o-ring rests) I do not use the o-ring that often. I was on a 315 mile ride a couple of weeks ago and only used it maybe 2 or 3 times for about 15-20 minutes maximum at any one time.
The handguards (BMS 1150 GS kit if anyone is going to ask) do keep one from simply "rolliing" the o-ring right off the end and into the ditch!
I have the same 'indentation' on my 2005 Tiger which does work well to rest the o-ring into.
I am going to have to get some of those BM hand guards so much better looking than the triumph ones!
fitting issues
I used the Cat-O-Ring trick on my sprint, however on the Tiger, the gap between the bar end and the end of the throttle grip is about 3/8" wide and of course the o-ring just falls into that gap. Before I go messing it up, can the throttle grip assembly be moved?
thnx!!
1 - 11 of 11 Posts
