Hi guys & gals,
I have heated grips on my bike, and due to some long rides we do Id like to get a cruise control.
Just wondering if anyone has used one in particular that is compatible with heated grips that they liked, or had no major issues with?
Cheers for any help!
This isn't true cruise, but check out Go Cruise. I think it's http://www.gocruise.com but if not, just google it. It's only about $20 and grips your throttle and braces against your front brake lever. When you are at the speed you want, just push the device against the brake lever and it will hold your speed. Obviously in doesn't change the engine speed on hills or have a resume like real cruise, but for twenty bucks it's sure better than nothing. There's a video on the website which is much better than my description.
Hi guys & gals,
I have had Kaoko cruise control on two bikes and they work really well. They are essentially a friction nut which holds the throttle wherever you set it. Not sure about compatibility with the heated grips but if you google the site you can email them. The response has always been very good and quick.
cheers
Blindaussie
