1 - 3 of 3 Posts
Just noticed several spider cracks eminating from the top screw of the right upper fairing. It almost looks like a stress crack from improper mounting/removing (just got it back from the dealer). There was/is no "pre-load" between the threaded mount and the fairing hole, which again leads me to believe it happend at the dealer.
Any suggestions for repair?
Being a former aviation mech. I've learned that fiberglass and epoxy has a tendency of being too hard and will easily crack. A possibility I have considered is epoxy and a piece of .020 aluminum.
What other materials have you successfully used?
You have to use the same type of plastic and "weld" it. Some folks have found that yogurt cups (like Dannon's I think) has the same type...just cut it into strips, melt the back side of the part with a soldering iron, feed in the fill plastic, and it's done. I've seen the results, it's pretty impressive. I've also seen someone use MEK.
1 - 3 of 3 Posts
