1 - 3 of 3 Posts
2012 Tiger 800 XC
Took a solid hit to my skid plate and cracked my oil pan. Leaks very slowly and still runs great. Hood Automotive tire Automotive lighting Automotive mirror Tire
Eye Automotive tire Wood Motor vehicle Automotive lighting
Easy fix may be JB Weld, but I’m considering a used pan or a proper weld. It seems like dropping the pan is pretty straightforward. Advice please! Thanks in advance.
Tiger 900 GT Pro Svartpilen 401
I've repaired a stator cover that took a hit from a rogue engine bar (bracket snapped and the bar pushed into the cover.) It came out OK. Cleaned it thoroughly with brake cleaner spray, filed out the crack for more surface, and gave it a layer of metal epoxy. Then I filed down the bit inside which threatened to rub against the stator.
In support of metal epoxy being able to fix anything I submit the following evidence of unknown origin. :)
Drinkware Gas Serveware Font Metal
1 - 3 of 3 Posts
