I've read thru several sources, and get confused by the actual compression specification for my T140V. Some sources say 7.9:1 others 8.5:1. The engine has Hepolite 19162 pistons. The Haynes manual refers to Low grade vs Hi grade specs. Is this referring to compression ratio and that the bike was available with different compression engines?
I ask because I may have to replace at least one of the pistons. I just can't get the top compression ring off one of them. If I need to replace, I'ld like to either replace one with an original Hepolite (if I can find one) or perhaps get a generic set of pistons sold on eBay for this model bike. Either way, I want to understand more of what I might be buying.
