I just replaced the coolant in my '02 ST. My factory manual says the capacity is 2.8 L, which converts to about 3/4 of a gallon, yet I only got about 1/2 gallon out. Anyone know the true capacity or where my other coolant hid during the drain?
Thanks,
Sasha
P.S. I did use the drain in the block as well as disconnected the hose from the pump.
Autos are the same way. That's why the 'flush' is so popular. Just draining the radiator and hoses leaves a bunch of fluid in the system.
If it really bothers you, you could always try hanging the bike upside down to drain;)
But seriously, if you want a better change of fluid, you can dump the old stuff, fill the bike with distilled water*, run the bike up to temp, shut it down and drain the coolant again.
Then, refill the system with coolant.
*However, this will result in a 'weak' mixture. To avoid that, fill the system in the 'flushing' step with the normal coolant mix.
Or, you can just change the fluid more often than the recommended interval.
