I'm constantly having my cooling coming out of my overflow tube after a ride. Causing lots of stains on my parking spot.
Is this a know issue?
I've had this problem if I've overfilled the plastic reservoir (overflow tank).
If you have done a fluid change you also need to run the bike and get all the air out of the system using the bleeder screw.
Good luck.
When this happened to me (2000 Sprint ST), it turned out to be a bad radiator cap. You can "rent" the test kit from AutoZone or Advance Auto to be sure.
Radiator cap. Sometimes just taking it off and refitting it causes it to be okay again - like magic, but it's on its way out so just replace it.
