morning all i am going to change the coolant on my 05 speed triple the weekend is there anything i need to know or any tips you can give me also i cannot find the washer size or type for the drain screws
many thanks
simon
Haynes pretty good for procedure. Do check the state of what comes out as it tells you what state the internals of colling system is in
Don't remember the size but fairly accessible. Instead of trying to get at the dregs in the radiator which will not drain out the block drain plug, I refilled with water and ran the motor. Drained and refilled with water a couple of times until it drained clear. Refilled with BMW purple premixed coolant. Remember to fill to the reservoir minimum line, bleed until bubbles are gone and you're set. Any more and speedy will piss it all away. Mine runs 6-8 bars on the temp gauge regardless of ambient temperature, age of coolant, anything really.
cheers billy10 i got a copy of the haynes manual couple of weeks ago
thanks surya i will follow your procedure
