Hi, can anyone advise on tyre pressures. I've just fitted a set of Conti TAs to my Steamer and wondered if anyone has any advice on tyre pressures. The manual states 30 front and 33 rear but I have read some threads which state that the TAs like to be firmer than usual. I am 13.5 stone (and rising all the time), ride mostly solo and 100% road. Any advice welcome, cheers.
Hmmm, just checked the Continental web site and its not much use:( My girly is 2.5b and 2.9b or whatever it equates to in English, check with the guy that fitted em(unless thats you)they should know best.
Hi, thanks for the reply. The later models standard pressures seem to be 36/42 respectively. I'll run the standard handbook pressures to start with. The Conti is a relatively new tyre for the Steamer and I have read on ADV that some opinions were that they were a better performer at firmer pressures. Thanks
Not much help I know, but I am on my second set of TA's on my 06 Tiger and I run mine at 36/40. Best to start at the book pressures and then play with them until you get it to feel right for you. :)
Andy.
