1 - 8 of 8 Posts
Hello, fellow self isolators.
The glass in the speedometer of my '99 Legend has cracked and I'm considering using a Dremel to cut the plastic case and use some silicon sealant / duct tape to effect a repair. However, I need a donor odometer / rev counter case. Would any of you learned people know which other Triumph models have clocks with the same bezel and diameter as the Legend TT? I was wondering about the 900 Trophy or maybe an older Bonnie?
Thanks and stay safe.
Andy
I haven’t measured them but others have reported the Trophy 900 clocks are a bit bigger. An older Bonnie will be tough, not sure if the speedometer would be accurate?
Cheers mate. I need to replace / fix the odometer but the 885 Thunderbird / Legend / Adventurer gauges are sooo expensive. I'm looking for any alternatives. Even if this means cutting the casing and reattaching the bezel and glass.
Andy
Cutting the casing and installing new glass and reattaching may be your best bet. Does it work properly?
i took the bezel off my thunderbird gauges , i got a small electrical screwdriver and bent the tip 90 degrees in vice, then slowly worked the lip up all the way round by using my thumb as a rest for the cdrewdriver and prying against it, i cleaned the gauges and clipped it back on and pushed the lip back down, this was 4 yrs ago and still ok, if gauge works you could easily and cheaply get glass cut for it,
I did consider this but the bezel is dented and has a crack so I'd prefer to replace it.
Discussion Starter #8
I wonder if I could source a broken? rev meter from a Thunderbird, Adventurer, Legend or S3 and cut this open to grab the bezel and glass. Anyone got one for sale?
Thanks.
1 - 8 of 8 Posts
