does anyone know if centrestands from Legends, Adventurer, Sport or other will fit the Tbird (01)? i'm having no luck finding the original part. (Hermy's don't deliver OS).
They should all bolt on, but will not function correctly because of the height of the legs.
With the exception of the early TBS one this is true - the early TBS one will give you a world of problems with spring mount locations and the position of the deployment lever IIRC.
If you can only find a Legend one it would be a fairly easy job for a welder to extend the legs for you.
