1 - 1 of 1 Posts
Finally got around to installing the kit on my 2015 T100. Fixing the fork performance was a must. I have past great experience with Cogent setting up my Ducati ST4S Ohlins front and rear. So had faith that his fork fix would be well designed.
The forks now give a supple ride and follow the road perfectly even when rough and bumpy. Cornering is more confident. At 220 pounds I went with the recommend 85 springs for street use. I could have used 90 but since I will not be on the track decided to go just a little softer.
I recommend this kit highly.
Now waiting for Ohlins replacement springs for the Kawi KYB shocks from Cogent. Even at 220 pounds the Kawi springs were too stiff. 00480-04 progressive rate 20-32 N/mm. $62 ea. plus shipping.
1 - 1 of 1 Posts
