1 - 16 of 16 Posts
Hi,
Just got myself a lovely project, a 1968 T100P, in need of full restoration, have stripped it down and blasted frame, swing arm etc, but was wondering what finish to go with, I have had gloss powder coating done on my old kettle and wasnt that impressed with its longevity as its gone dull, whats your opinion on Coach paint ? or is it just a case of find a better powder coater ? I'm not getting all anal about the resto as Im changing the colour scheme and fitting a TLS but want frame to look good and last, also I'm in the UK, where do you guys recommend for parts as there seems to be a lot of copy/universal parts advertised on the net.
I generally get my spares from TMS Nottingham. (and others, Tri-cor, etc)
As for the frame, I get mine blasted and primed.
A light rub-down with Scotch-brite, grey primer and three coats using black rattle cans, finishing off with a couple of clear-coats.
If you`re not into DIY, get it powder coated, make sure all orifices are masked-off.
I've always used coach paint and got a pretty good finish.
The current build that I'm doing is a cub and it's been done with paint called Flowliner from C Wylde.
In the thread that you linled to, the poster got the OIF problem a bit wrong, as a bit pf paint in the frame is probably ok, but it's the blast media that's the risky bit due to grit getting in to the tank. It's a bugger to get out again.
My T140 was originally powder coated ( I believe) and I pretty much redid the frame 25 years ago with a brush. It's still pretty good and I'd have no hesitation doing it again.
There's a place in Windsor quoting £70 (ex vat?) to do a swing arm and frame but I'd still rather "waste" hours on a wire brush and tin of paint in preference as touching up is fareasier.
Cheers Chaps, thats making my mind up for me, Id read some good reports Dave on Flowliner but Ill also check out tekaloid :)
Dave,
how much flowliner do I need to paint frame swing arm etc etc they sell in 250ml tins, also as frame been blasted back to bare metal, do I need flowliner primer or etch primer ?
cheers
I'd use some etch primer in a spray can, then use some high build if the frame's a bit rough.
A 250 ml should do you, I've bought several tins but was also doing fork legs and a nacelle at the time. try to do most of it in one go as you'll absorb a fair bit in brush cleaning
I spoke to the guy at Wylde's and he was helpful.
I use(d) Tekaloid coach paint, it's been used & recommended for years on classic bikes and coaches..
I'm not sure if 250 ml is sufficient ? I bought Tekaloid T318 Black from Avenue Coatings in Slough (I couldn't find a supplier in the N.West) ,1 litre did me for two/three coats of the frame & s/arm, I've got about 250 ml left over. I think just as important as the paint, is the quality of brush - I used a Hamilton Acorn brush, forget which type but they're v.good.
Discussion Starter #13
Good advice about the brush, had already read up about Hamilton brushes, Ill have another look on Tekaloid site, I figured at least 500ml
cheers :)
Discussion Starter #14
Bought a £12 Purdy Monarch Elite brush, and although I wasn't so happy after Id applied the grey tractol primer to the bare metal, after flatting it down and applying a liberal coat of tekaloid black coach paint, the finish is really really good, did the swing arm and stand first, takes a fair old time to dry...but Ill move onto the big stuff now :)
Just for reference - noting where you are - I use a place called Chicago Powder Coat for all my blasting and powder coating. They are in Mossley (SE Manchester) and have done a couple of scooters for me. They charge about £120 to blast and coat a complete Lambretta (about 24 individual pieces) so I expect a bike frame would be < £100.
I'm considering using them for my T100c resto but I also like the sound of Tekaloid. I'm not sure I have the patience / temperment to get a good finish with gloss though:rolleyes:
Discussion Starter #16
price sounds ok, I was lucky I blasted all parts for free, so only cost was brush & paint..£52
I know it wont be as good as a professional ( or maybe it will ;)), but I got a bee in my bonnet about doing it myself and luckily have a few days hol
1 - 16 of 16 Posts
