I am gather parts for a zrx front end swap and I thought I would look into swapping out or ideally upgrading the clutch master cylinder so that I can have a unified look when I swap out the brake master cylinder. Looking around I have found a few options and I wanted to get some opinions as well as compile some information about what would be compatible with the stock setup regarding master cylinder bore sizes. From past posts I believe the stock bore size is 14mm but you could get away with a 5/8 in diameter bore as well, does anyone have any information to confirm or deny this? Here are three options I have run into in my research.
The biggest unknown of this whole project is the bore size issue, so if anyone has any input or knowledge of the solutions I threw out there let me know. Also if there are any levers I have passed over, bring them up.
- OEM ZX7R - This option was used by MickMaguire in his front end swap and I believe this has the same size bore as stock.
- eBay fake Brembo Ducati - I have no idea what bore size this is however they can be had for very cheap (~$30), but they could be a complete waste as the quality is in question.
- OEM ZX14 - For me I think this is the ideal situation however I can't find the bore size for the life of me. The reason why I think this might be the best solution is because this is a radial master cylinder giving an upgrade in performance and feel . In addition when I upgrade to the dual calipers I could use a ZX14 brake master cylinder and have similar levers.
