1 - 3 of 3 Posts
Hi all,
Looking to see if anyone can suggest any type of clutch kit to replace on my 2k model,anyone fitted one recently?if changing did you use upgraded springs or are standard ones ok to re-use?
cheers. :)
I recently replaced the clutch in my 1999 S3 with 30,000 miles, and could not find aftermarket plates and springs. I went with OEM and was advised to get new springs to be on the safe side. Six new springs at $4 USD each was worth the peace of mind. I believe total cost for the clutch parts was under $300 USD.
cheers b shell,found a supplier ebc full set of plates and upgraded springs,£60,only friction plates mind you.thanks again. :)
1 - 3 of 3 Posts
