My clutch is slipping or just not fully engaging in high gears. It probably isn't fully engaged in all gears, but it may be just more pronouced at high gears due to a lot more resistance to forward motion. My cable tension adjuster is loosened all the way in an effort to get the clutch fully engaged, but apparentally it still needs more adjustment. Any ideas what would cause this? My initial thought was the cable itself. I sure hope its not the clutch assembly itself...thanks for the help.
