1 - 2 of 2 Posts
Does the thruxton r have a starter/neutral fuel map that will stay engaged if you remove the clutch interlock switch at the clutch lever?
So I am replacing my levers and the aftermarket ones I got don't have a reliable switch built in. From a search of the internet I found some grumblings of a starter or neutral fuel map that may or may not stay engaged when you have that switch bypassed because the ecu thinks you're in neutral permanently this was also on the twin section of the forums. I am looking for some definitive information on it to save a lot of heart ache in rewiring and pulling apart the oem assembly.
1 - 2 of 2 Posts
