Plan on changing my clutch fluid. Considering the length of hose from the reservoir to the bleeder screw, how much DOT 4 fluid is required to replace the old fluid?
Thank you in advance.
You wont need very much at all, I can change clutch, front and rear brakes on one 600mlbottle of fluid.
One small bottle will be great plenty unless your reservoir and slave cylinder are especially gunky...:)
