Hi,
I've just finished rebuilding a 1970 T100S. I bought a new clutch cable and got the right length according to the parts manual (outer 42 inches, inner 46 inches). However, when the cable is fitted and adjusted to 1/8 inch free play, the cable adjuster at the handlebar is almost completely screwed out of the clutch lever mount. Have I done something wrong? I have the longer clutch cable abutment piece (the metal sleeve that slides over the lower end of the cable) so as far as I can see I should have taken out the maximum slack possible. Should I be using a different cable (if so, anyone know which one?).
Tony
Tony
