ok, so I dropped the bike. I was going slow and making a u-turn. Chalk it up to inexperience.
I broke the clutch handle and the peg on the shift lever. I also replaced the shift lever since the peg broke off and it could not be extracted. All were easy to replace.
The problem is adjusting the clutch. I cannot get it set right. Can anyone help out? Where should the adjuster at the handle be set to start with? Should I start this adjustment at the lower end of the clutch cable?
Since I have replaced parts at both ends of the cable, I think I need the new clutch cable instructions.
Help!
oh yea, 2009 Bonnie SE.
Help!
