Well, went and took the 01' triple for a test ride yesterday. it got to 45F outside so it was beautiful! The bike rode great and I had a blast on it. I don't know how you can keep this thing under 80mph!! The only trouble I have with the bike is when I'm going to start the bike up. Kickstand down, neutral selected, clutch in, and I hit the start button. Fires up after 2 seconds but the second I start to bring the bike off the kickstand and completely vertical, the neutral light flickers and then the bike kills. I have to keep fidling with the shifter to get it to stay in neutral correctly. I think it took me 5 trys before I was finally able to put the kickstand up and into gear without it killing. It's also very hard to find neutral. The clutch pull feels pretty loose so I'm thinking I just need to have it adjusted. The front brake is also a little loose.
So, do you guys think a clutch adjustment will fix the neutral problem? Also, how much do you think it would cost to have the bike looked over at a dealer and have the clutch and front brake adjusted?
