l have a big problem, l cannot unscrew the two cross head bolts on the top cover of the fluid reserviors on my Sport. l have tried all the usual methods, WD40 , impact driver, some heat ( remember they are painted) and no luck. l do not want to risk tearing them up , so heres th question, can you pump fluid up the pipes and into the reservoirs .l know that there are pumps that push fluid into the system fom the caliper nipple when you cannot get fliud through by pumping the levers as you normally do. Anyone tried this or is it worth a try.
l suppose as a last resort i could drill a small hole in the cover and syringe fluid in then plug the hole. Not a good selling feature though, not that ever l plan to sell her .
