1 - 3 of 3 Posts
When you open tuneboy sensor screen you have the closed throttle reset do you use this with the bike running or with just ignition on and if with bike running what temp should the engine be before you use it i know that the tp has to be zero in first screen before you do this thxs in advance for help
IIRC, the engine should be running to reset throttle position. Read your documentation, and it should tell you.
its says on the tuneboy pdf that the throttle position reset which is the first screen on the virtual dash that you click this then turn on the bike to idle but on the second screen is the closed throttle reset what i am trying to find out is what engine temp should you click this to reset it
1 - 3 of 3 Posts
