1 - 3 of 3 Posts
Hello all,
I am having a hard time putting the chrome clamp covers over the clamps that hold the pipes on. I have a 1998 Triumph Thunderbird Sport. Any tips on getting this done easier?
Thanks,
Jack
Shouldn't be a problem. open the clamps as wide as you can with the bolts in, put the cover arms inside the clamp, and slide the whole lot over the exhaust, adjust position and clamp up. The only ones I have has problems with were when the exhaust was opened out to remove it from a bike.............in which case clamp it up before you put the covers on and then release it and fit the covers as per the first part of my post.........phew!! :)
A little profanity and a lot of patience will help. The left side took me about 30 minutes, and the right side was finished in less than 5.
1 - 3 of 3 Posts
