have removed the restrictor plate from air box, want to make sure my jetting is at least close to what it should be, running a 790 motor, 130 main jets, stock needle with 1 shim, two turns out, 42 pilot jets, enlarged filter plate hole, tors exhaust, unifilter, with a 18 tooth sprocket. thanks for the help. on a 300 mile run today it averaged 47mpg.
