1 - 13 of 13 Posts
Hey guys
The time has come for me to change the chain and sprocket on my
My loved bike.
But im not sure what tools i need. If anyone has the time to make one it would be much appreciated.
Some general tips and tricks and stuff i should think of?
27mm socket for the rear axle nut. 36mm (I THINK) for the front sprocket. Make sure to loosen that front sprocket nut before you cut the chain.
so i really need to cut the chain with a power tool?
Friend told me this but i didnt really belive him :/
You just need a dremel tool with a cutting wheel. You can usually get them really cheap if you do care about brand name or quality.
The front sprocket is 35 or 36- if someone can confirm this.
dremel tool is def easier to get hold of! can anyone confirm the size of the front sprocket? Ill need to go pick it up at at HW store
If you are doing the whole thing ... Front/rear and chain
Start with the front sprocket. Its best to use the old chain to help break the nut loose on the front countershaft. These things are usually very tight, so you'll need a large breaker bar and a 36mm socket, a deep socket is best so your breaker bar clears the frame. You also need something like a wedge with a sharp point like a wood chisle to get underneith the folds of the safety tab washer and bend it back so the nut will turn.
Here is how I do it...
Stand on the right side of the bike, put one foot down on the rear break, reach over top of the seat and pull up on the breaker bar to loosen it. You can also put something in between the wheel spoke and the top of the swingarm like a hammer handle, piece of pipe, etc.. if you are having trouble holding the wheel with just the brake, but be carefull not to put it on top of the brake line. Like I said, these things can be super tight.
Also, depending on the chain you get and the masterlink you choose you might need a chain rivet/press tool. Whether you get a clip style link or a rivet style link, Id recommend getting a link press to press the plate on properly. Rivet tools can be pricey for a good one so the clip link is the "budget" option. Right now I'm running a clip style link and its holding up fine. (RK X-Ring Chain)
The rear sprocket is fairly self explanitory. Once the wheel is off the cush drive will basically pull apart and you can inspect the bearings and grease and the condition of the rubber blocks.
You will need a breaker bar. You can use a c-clip link but I would safety wired it and then use red gasket (comes in a tube) material to cover it. I did this with my track bike and never had an issue. Just check it very once in while.
Also, EK chain now has a master link that uses a 8mm wrench to press the links together. Therefore no tools are needed. I have used this on my TT600 and no issues as of yet.
I really, really like air impact wrenches for front sprockets. It's got around 80 ft lbs of torque on it. You can get it apart with a bar and socket, but air is the lazy way out. It is a 36mm nut. Be sure to replace and bend up the washer when you put the front back on.
Discussion Starter · #9 · (Edited)
Got myslef the following items
JT 14/42 Sprockets
EK QX Rring 525 chain
3/4 Bar and 36mm Socket.
Rivet tool for the chainlock.
Friends got an angle grinder thet should make short work of the chain.
try doing the job tomorrow prolly be alot harder then im imagening so wish me luck
Discussion Starter · #10 ·
well that sucked, the lock was not properly secured so the bike spit the chain off after about 2km luckly nothing easle happened. days work gone wasted yay
On my Bonneville, the drive sprocket is to be torqued to 135Nm, did you have a chain failure or a nut loosen on the drive sprocket? The bell lock nut is to keep that from getting loose. Glad you are OK - chain failure can be very ugly.
Discussion Starter · #12 ·
The chainlock failed, i attached it wrongly, first time changing it.
Gonne get som help from a friend today so ill be set correctly this time.
Just happy it didnt happen at a higher speed and that the thing dint breake anything!
1 - 13 of 13 Posts
