41 - 48 of 48 Posts
I think my Bonneville is about 2 1/4 mph faster when I use vegan bacon grease to lube the chain versus using the real stuff, even when using the thick cut style bacon. Go Vegan !
I'll have to go with the WD-40 (to clean) and Dupont Chain Saver crowd. I had used the Maxima Chain Wax previously....it did work well, but cleaning the chain (w/ WD-40) in between took quite a bit of time (at least in my hands). Quite happy with the current regimen [plus one can use the liquid (vs. spray) version of Chain Saver in between cleanings if needed].
I’ve always used paraffin, dry then 90w gear oil.. awesome mileages all year round but I may try acf50 as I’ve read a few good reviews...has any one seriously tried it?
I live in London and don't have a garage, plus I know how bad/negligent I am when it came to oiling the chain on my old 125cc bike. Now I've got a Bonneville I want to treat her right. To that end, anyone here ever use the scottoiler v-system?
Never cleaned the chain and used DuPont Chain saver best stuff ever. 59,000 miles on the chain and sprocket set on the Scrambler and spray it about every 600 miles. Stuff is amazing......
i use ep90 oil , sealed chain so its lubed internally wise.
run a rag of ep90 over the exterior keep rust at bay on side plates and rollers, rest is sealed. tiny fling , but a litre lasts forever.
clean with either parafin or WD40
41 - 48 of 48 Posts
