1 - 20 of 52 Posts
What does everyone use on their chain? I've been using this stuff because it doesn't flick oil all over my back wheel: Maxima Chain Wax - RevZilla
Now I'm wondering if it does as good a job as regular chain lube does maintaining the chain. Thoughts?
Been using Maxima chain wax for five years on my Thruxton, it works great. I ran out once and bought some Honda branded chain lube which splattered all over my wheel and chain guard.
+1 on Maxima chain wax. Have used it for years with good results, very little fling and minimal chain and sprocket wear.
By the way, I started using a Grease Ninja for chain lubing. It’s $15 worth of “I could make this myself “ but makes lubing less messy than spraying from the can even with the straw.
  • Like
Reactions: VABird
When my current lube (Rock Oil I think) runs out I'm going to start using EP90.
I clean mine with any good chain cleaner (Motol, Muc-off, etc) and lube it with Amsoil Chain Lube. It doesn't fling off and does a good job.
Every 600 miles after a ride, while the chain is hot, I wrap my chain in bacon. I let it sit overnight to cure. The next day when I ride, I have to admit, there is a bit of a mess. But it smells wonderful, and my chain last a very long time.
That sounds great until all the neighborhood dogs chase you down the road nipping at your ankles!
Driftless Admin
And the nasty stares I get when I ride past the hog farm.
Post number #16 and no one has posted the chain lube youtube video, or the youtube video about the chain lube youtube video. We're getting sloppy.
Any particular brand of bacon? I want be certain I get the full 600 miles from each wrap. ?
Driftless Admin
I haven't bought that thin cut vacuum wrapped stuff for years. With the fake "maple" and "hickory" flavorings. Well worth spending a few extra dollars on the thick cut stuff at the deli counter. And with the extra meat thickness you can really press it into the chain, so it holds better and lubricates the o-rings better.
Sorry for going off-topic, but also if you mix a quarter cup bacon grease with a quart of dyno motorcycle oil, the product is the equivalent of full-syn moto oil. And it smells better.
And more off-topic: I'm having a hell of a time keeping the raccoons and opossums out of my garage. Any tips for that?
1 - 20 of 52 Posts
