My Scrambler is the same way, although it's a little higher off the ground. I've only had the center stand for about a week. I have the chrome passenger rear grab bar installed, so I grab that and the left handgrip, push down on the stand to steady it so both of its feet are on the ground, and like Geoff said, try to push that thing through the floor while pulling up with your right hand. A slight backward roll can sometimes help. I only weigh 125lbs, so it's a chore.
Also, getting it down can be nearly as tricky. The stand wants to slide on my garage's smooth concrete floor, so I put my left foot right in front of the stand to keep it from sliding, grab the left handgrip and rear grab rail and pull forward on that, making sure to keep the handlebars straight so it doesn't get too close to me and start to fall away from me.
I sure did get spoiled throwing those little 250cc Suzukis around during my MSF classes.
