1 - 10 of 10 Posts
Just wondering if there's any reason to prefer the "Triumph" branded center stand vs. the Norman Hyde version? I see that Newbonneville.com has the NH stand about $30 cheaper than the Triumph price, is there any real difference between them? I'm used to paying the "Triumph Tax" for anything that's got the T logo on it but see no need to do so on a utility item like the C-stand.
Is the stand the same for the Scrambler as it is for the Bonnie/T100/Thruxton? I was wondering if the Scram stand might be a bit taller to account for the Scrambler's higher stance.
No reason really.
I tried to put the Bonnie stand on the Thruxton, to discover it would not fit - and had to order the Triumph Thruxton version, which is slightly longer.
I also put Hyde classic silencers on the Thruxton.
Despite what Hyde say - that their exhausts work with the centre stand - the dealer had to fiddle around to get them to extend and retract properly.
So if you go for Hyde centre stand - get them to confirm in writing that they will:
a. work problem and installation free with Triumph silencers
b. as above with their own silencers
Nothing like pressing home the point!
The stands are different in so far as they have different stops. The Bonnie/ T100 stand stops up against the bottom of the muffler. The Scrambler doesn't have a muffler there so has a different stop (don't know how exactly) Ditto Thruxton as muffler is upswept. I do believe the Scram and Thrux are a little taller as well but not 100 % certain.
Center Stands
Neither! Too much $$ for too little. Got a jack(lift) instead & can do anything w/ it!
Plus- no extra weight on the bike!! Oh yeah & 1 less thing to break.
So will the scrambler stand fit the thruxton?
Don't know the answer to that one. I know that I had to modify my T100 stand when I fitted the Scrambler exhaust as the stand came up far enough to hit the chain.
Keep your eyes peeled on Ebay. I picked a genuine Triumph stand for about $50.00 less than the dealer. It was brand new.
Also, there are several threads about installing the center stand,and some short cuts that realy work. Check em out...
Get a center stand though, ya gotta have one....
Cheers....
NH vs Triumph center stands
I can tell you this much: On my '98 Thunderbird, I installed the Triumph center stand. On the '08 T100, I have the Norman Hyde.
Both installed with the same effort and procedure.
IMO, the Triumph stand may have been a bit taller, as I recall the effort required to get the bike to go over center was higher on the T-bird than it is on the T100.
Of course, the T-bird may have been HEAVIER than the T-100 also, which would affect this also.
Since the NH stand is cheaper, and, from all that I can see, JUST as well made and sturdy, why NOT save the $$$?
Bob
I'm going to be putting a center stand on this spring. I haven't made a decision regarding new wheels with the exception that the stock rims and spokes are a temporary thing. I was wondering if a Bonneville center stand will work with a:
1. 140/80 x 17 tire
2. 140/70 x 18 tire
or will it be too short?
Either way I'll be moving away from the stock size. Anyone have experience with a center stand and either of these tires?
Thanks,
Joel
But no good for adjusting the chain, or mending a puncture while on a run,
1 - 10 of 10 Posts
