Can anybody tell me if the triples suffer from carb icing?Coming to work today,engine misfiring and would not idle.The throttle felt very heavy and unresponsive,als
ver 3500 rpm would clear up and be OK.The weather was foggy and around zero degrees.Does this sound like the symptoms to expect?One extra thought,switched off at work,clocked in,then restarted after no more than two minutes,the bike ran absolutely fine. Idled properly and revved up correctly
