Since my bike has been running fine for the past several months, I waited until today to check carb balance. After 15k miles since last rebalancing, and using an ultra sensitive home made manometer, the balance was spot on. I fired her up with one hand close to the kill button, expecting one carb or another to pull a much higher vacuum than the other. Nope! The two fluid columns were in line with each other from idle to approx 4000 rpm. Turning the screw one way or the other would only have made it worse.
My kind of balance job!
Bob
Bob
