I've always had mine plugged into the garage regular wall outlet. I don't think you're supposed to use an extension cord with them.
I wouldn't worry about running a new circuit/breaker unless you have problems with constant tripping, I'm sure what's in your garage will be fine.
They can make some really nice welds, I've gotten to where I can make some nice "row of coins" welds with mine, and it's just a cheapie flux-core.
I do run the .035, but it can run the .030 with different tips. I like the bigger .035 because it burns brighter and it's easier to see through my shield, which is an auto-darkening #11 lincoln shield from home depot.
Once you tune it right, meaning get the knobs adjusted for temperature, and wire speed, spatter shouldn't be a problem. If you have a lot of spatter then your wire is moving too fast for the temp you're welding.
Spatter really isn't an issue. They are a lot of fun too.
tools you'll need:
-angle grinder and a ton of cutting disks, and grinding/sanding disks
-drill (I have a stepped bit which wasn't cheap but it's great)
-big ass bench vise
-steel table sure is nice, but not necessary.
-big wire brush
-clamps/vices etc
-speed square, tape measure, etc
that should get you a big start.
tools you'll need:
-big ass bench vise
-big wire brush
-clamps/vices etc
