Hi...
Does anyone know what CAN signals are used on the ST 09 ? Looking at changing the clocks to a smaller sportier look with a few more mods. Just wanted to know what signals are sent on CAN Network.. I know fuel level is, anything else.. ??? :unsure: Cheers.
Oh ....... Also - I'm not 100% sure on your year/model but it's possible that you may not even be able to start without the CANBUS instruments connected - so before you put too much effort into it, disconnect the OEM at the instrument connector and be sure that it WILL start ...................
You might be better sticking with some OEM CANBUS instruments, like from Speed Triple for example - that will give you compact look but might just be the simplest way around things
