I have a 96 1200 Tropy. Upshifting to the higest gears is a pain becuase of the position of the foot lever. I actually have to lift my whole boot off of the rider peg to push the lever up into 5th and 6th gears. And I have a size 13 (47) foot. I was thinking of removing the foot peg and seeing if the clutch lever could be rotated downward. That should decrease upward throw distance. But I don't know if the lever can be rotated and the Haynes manual does not offer a clue. Anybody done this?
Do you mean the position of the shift lever? The shifter can certainly be adjusted, and I don't believe you have to remove the footpeg. I know I moved mine a few years ago. I had my footpeg off to do something else, and I did the adjustment at that time, but I don't think you need to remove the peg.
If you do remove the peg, it takes a 6mm allen wrench, a long extension, and a bit of patience to work around the chain. I used a 10" extension, a universal joint, and a 6mm allen wrench in a socket to remove mine.
Good luck!
Good luck!
I definitely mean the position of the shift lever. It does not align with my foot at all--I have to constantly lift my foot off the pet to upshift and downshift, and I never had that problem with any other bike. What I hope to do is rotate the shift lever downward--Is there a faster that holds the shfit lever to shaft or spline?
If you go to Bikebandit.com and look at the schematic for the Gear Change pedal (under the tab for Transmission) for your Trophy, you'll see a double-threaded rod w/2 nuts on it. On the schematic for my '96 Trophy, the parts are labeled #5, #21, and #22. Loosen the two nuts (one is a left-hand thread, one is normal right-hand thread), then twist the rod until the shifter is located where you want it. Finally, tighten the two nuts again and go ride!
Have fun!
I see what you are talking about and will give it a try.
How much difference can this make? I need to bring mine down a good amount.
Should the lever ratchet up and down as you shift? On other bikes, I think the position of the shift pedal stays the same no matter what gear you are in. On my Trophy, the pedal "climbs" higher with each shift. Is that normal?
