1 - 3 of 3 Posts
i am looking at upgrade options for my sprint rs....
i don't want the whole new engine, but i would consider a top end head and cams...
i just don't know if the 02-04 daytona head and cams will work with an early 955 motor...
thanks,
Chris
I think it won't work, but I'm not 100% on that. Check the Sprint forum to be sure; there are some serious experts there.
'97-'98 Sprints have the 885cc engine with carbs; you have a '99-'01 engine.
I do know that the upgrade most people will recommend is a Daytona engine from the same era. ('97-'01 for the Daytona motor.)
Going to any '02-up motor will require lots of electrical changes & assorted extra parts.
It's often cheaper to buy a whole motor than to get parts.
Cheers, HTH,
-Kit
This engine was heavily updated in 02. The part numbers appear to be different between the 01 and 02. Try the following link. www.triumph-ant.co.uk This fellow knows his stuff when it comes to Hinkley Triumphs. He might be able to provide you with a head if needed.
1 - 3 of 3 Posts
