can anyone tell me what the riding position is like compared to the 06 ? I think the handlebars are 30mm higher & am wondering if it is a good idea to get the handlebar kit for my 06.
thanks
thanks
Mate, What do you mean by one full turn at the front? Do you mean one full turn in from the factory position? I think I've done a little more than that.I'm 6'1" and 220 lbs and found a fairly good balance at 1 full turn at the front ....
How did you get on with the riding position on your trips ? Do the handlebars work ok with the aero screen ?
???? Did they change something for '07?On 2007-02-01 07:10, oldgoat57 wrote:
The turn on the front suspension is the compression not the preload. If you want a stiffer front end you have to change the springs, That will change your preload
