Recently I've been hopping on the bike and trying to fire with no avail. One crank and that's it. I recently replaced the battery and thought that would do the trick, but clearly it not that cause I've had to charge it up twice now. What could possibly be draining it? Where do I start? This is...
Hi folks,
Can someone please confirm the kind of pads I need to replace those stock in my 2011 Speed triple?
Do these brembo calipers require special pads?
Mine seem to have around 2-3mm left but are making this worrying high pitch squeal (front). I will clean, but probably best to replace...
Since I bought my Speedy I've always had a vague notion of putting a 1050 engine into it at some point. I was idly scrolling in a Facebook group recently and came across a deal that I couldn't pass up, £350 for a 2012 engine with an unknown knocking noise. I figured "Why not" and bought it, I'm...
(2010 Triumph Speed Triple)
Hey,
So yesterday I tried to start the bike after 5 days of not riding it. (It's been pretty cold in the UK) but haven't had any issues starting her in the cold till now. Everything sounded fine in terms of the starter motor but would cut out/stop all electrics would...
Hi all, quick question on replacing the coolant temp sensor as i've had no luck finding the answer. Do I need to drain the system before changing it or can i just swap out and maybe top up any lost coolant?
Cheers in advance.
A forum community dedicated to Triumph Motorcycle owners and enthusiasts. Come join the discussion about performance, racing, cafe racers, bobbers, riding, modifications, troubleshooting, maintenance, and more!
