I'm doing rear brake pads this weekend, and took a look at what that will entail.
The caliper bolts don't look to be Torx or allen head? Any idea what sort of a bit they take?
I "searched" and someone said T-55 Torx, but don't Torx have sharp edges?
Thanks,
(1995 Sprint 900 btw)
All you could ever want to know about Torx is here:
http://en.wikipedia.org/wiki/Torx
The bolts that hold the caliper on are T-55, the pad retaining pin is, I believe, a 5mm Allen. (4mm?)
-Kit
The threaded pad retaining pins can be tricky. I ruined one the last time around and had to drill it out. Reassemble with some copper grease on the threads.
Thanks guys.
I got the retaining pins out as they were just allen wrenches and not too tight.
I don't think I've ever seen a Torx that big (T-55), so that is my excuse why I doubted it. I guess you need one if you're going to ride Triumph.......:)
+1 on the anti-seize for the pad retaining pins!!! I actually met the previous owner of my Sprint RS when I brought my Trident's rear caliper to his machine shop to have a pin removed.
I was used to T-8 Torx bolts from my work, so I know how you feel!
-Kit
