1 - 9 of 9 Posts
Parts book calls for;
97-2270 / H2270
Cable retainer
Anyone have a picture of how and where it mounts? It looks like it just press fits into something or maybe a screw goes in the back but I don't see any hole on Doris's port side forks for it to press or screw into.
Thanks in advance.
It goes into an "L" bracket that bolts to the lower tree pinch bolt.
It goes into part #46 on page #46 of the 1970 parts manual.
Uses a star washer to hold it on the back side.
Thank you Sir!
It's the same number on my parts manual but the "46" looked like a "45" which is a bolt. :nerd: (That was WITH my glasses on!)
So since it's a star washer the retainer can swivel a bit when the forks move?
The Bonneville Shop wants more for the white one because it's for a 1969. Aint that a pisser? Anything 1969 costs more! :frown2:
I like the black better because it's easy to change cables, it won't stand out AND it's cheaper! WIN WIN WIN! :grin2:
Thanks again!
I thought they were the same part only different colors, how is the black one easier to change cables? The white one pictured looks split in the middle, is it not?
I don't have one so I don't know for certain but it looks to me like it is solid and not split.
ETA
It is solid. Here's another picture.
I don't know about those, but I found with boats and zip ties, the sun and elements seems to effect the white zip ties more than the black. The white seem to get brittle quicker. I am thinking they maybe be the same type of material as your cable holder.
Discussion Starter · #9 ·
They are also used to retain the front brake cable to the front mudguard. They fit into a hole a few inches back from the fork leg on the right hand side.
http://www.ebay.co.uk/itm/97-2270-B...017217?hash=item3aacc9eb01:g:~QUAAOSwPcVVoOxB
Doris has many holes but that is a hole she lacks.
That may be a later addition.
I HAVE seen the brake cable zip tied to the fork leg before. Never seen the need for that but this little gizmo neatly tucked behind the fork cover is a pretty neat bit of kit.
I might as well get one ordered while I'm hemorrhaging money on the old girl! :wink2:
1 - 9 of 9 Posts
