Hi all,
My first post on this forum. I am the proud owner of a 2008 Speedmaster, the only one on Aruba and probably the only Triumph here:)
The front break fluid reservoir keeps leaking and therefore I want to replace the rubber seal (called diaphragm?) and also buy a nice new cap for the reservoir.
Any suggestions to where I can buy the seal online (would be nice if they had the cap also) and what is the right seal for a 2008 speedmaster?
I found one with serial number 5568471-001 but on the expoited view it doesn't look the same as mine. (mine has a cap, than a plastic part and than the rubber seal).
Best regards,
Jock
That looks like the right part number. Try Bike Bandit:
click here
Your rubber seal is probably fine - most likely if you replace the cap with one of the nice billet ones that will take care of the problem, as it will clamp the seal down properly.
Enjoy your bike, and welcome to the forum!
Thank you all,
I ordered a nice cover from newspeedmaster (together with a clutch lifter dresup kit).
I'll try this with the current seal first.
Best regards,
Jock
