Hi! I am going to install busa calipers on my 06 Sprint 1050 ABS... I know that Triumph's factory lines are ok. Maybe it is a stupid question - will ABS work fine after this change?
Yes they will but don't allow all of the fluid disappear out of master cylinder and ABS set up. :eek:From what I have read it is a bugger of a job to bleed the system again if you let too much fluid out.
