1 - 8 of 8 Posts
Hello, I serviced the bike and found that it burned some oil. Is it the fault of the bleed pipe from the sump.
some opinion?
Hi Alexandros :smile2:
Some Tiger's do use a lot of oil. Mine does.
I wouldn't worry about it, especially in a country as hot as Greece !! :wink2:
You might want to do a compression check.
Even getting to the valve guide seals is a bit of a project on these things.
1 - 8 of 8 Posts
